Basic Kit comprising 2 x Activ8 18m Quad Pet PIR's and 1 x Accenta Gen4 LED Compact.
8 Zones
3 part set programs
operation
Personal attack facility
5 Digi-Outputs
New LED Keypad
The LED remote keypad operates with the Accenta and Optima Gen4 intruder systems. Up to four LED or LCD keypads can be connected to the system.
Fire Zone
250-event log
Duress Code
Chime
Can be used to select a low security chime alarm for various areas of your house, even when the main alarm is turned off. When a door is opened or a detector triggered in an area set to chime, the control panel will deliver a low-volume ‘bing-bong’ sound to alert you. This is ideal for areas that require low level monitoring.
Built-in tamper control
To protect all wiring and detectors in the system from unauthorised access including the control panel and remote keypad covers.
This product was added to our catalog on Wednesday 21 April, 2010.
