£3.05 Ex VAT
OBSOLETE The GF2100 has an RJ45 plug and Cat5e lead connected to a terminating box containing a Max Headroom? GF0080 (Colour-coded tool-less...
£15.15 Ex VAT
£9.62 Ex VAT
CQR SC570/WH/MULTI Multi Heavy Duty White Micro/Switch Contact with Selectable Resistors. GRADE3
£37.78 Ex VAT
High efficiency, cost effective range of Switch Mode power supplies for use in Access Control, CCTV and General Purpose applications. Modular...
£14.40 Ex VAT
Both the ACT 2323 and ACT 1313 should be fitted as standard to protect against false alarms and system malfunctions caused by induced AC and nearby...
