- 1-10 Input / Zone (Small)
- 11-24 Input / Zone (Medium)
- Control Panels All
- LCD Remote Keypads
- LED Remote Keypad
- On Board Keypad
£1.09 Ex VAT
D20 5-Terminal Single Reed Surface Contact White Colour: White Environmental Class 2 Operation Gap : 20mm Approx Dimensions: 67mm x 14mm x 13mm...
£248.48 Ex VAT
The i-onG3MM is a Grade 2 or Grade 3, 10 zone intruder alarm panel designed for mid-sized installations such as office blocks or...
£31.35 Ex VAT
The Eaton M12 is a 4 in 1 Smoke detector combining: Optical Optical + Rate of Rise Rate of Rise Fixed temperature The M12 can be set to...
£29.54 Ex VAT
SCANTRONIC A tag acts as an alternative to a user access code. You can assign a user a tag, an access code, or both. You cannot assign a tag to the...
£57.35 Ex VAT
The EXP-W10 is a 10 zone wired expander designed for the i-onEX range of control units. This expander provides connections for: Either 10 Fully...
£15.35 Ex VAT
