£2.50 Ex VAT
A multipurpose IP56 rated black ABS enclosure with a strong, robust and reliable ABS construction Dimensions (Internal...
£3.30 Ex VAT
• 6 Terminals • Cover and Wall tamper • Available in White, Grey or Brown • Environmental Class II • Size 85 x 25 x...
£9.07 Ex VAT
150mm x 40mm x 10mm deep spacer for use with and Roller Shutter Contact. PARTICULARLY USEFUL IF YOU WANT TO FIT A G3 ROLLER SHUTTER -YF10C TO A METAL...
£6.72 Ex VAT
Dual Flash Led Unit for Bell Boxes battery not included, 1 x CR123A lithium battery 3V required (white light so will flash through...
£24.16 Ex VAT
9.3m / 360˚ coverage Quad element pyro Optional Low sensitivity mode EN50131-2-2 Grade 2. A security system is only as good as its ability to...
