The EXP-W10 is a 10 zone wired expander designed for the i-onEX range of control units.
This expander provides connections for:
Either 10 Fully Supervised Loop zones OR five Closed Circuit Loop zones.
One loudspeaker.
Four, wired, programmable outputs.
The unit is housed within a white plastic case, which has a built-in shrouded back tamper and internal clips to hold the i-rc01 four relay output expander card.
In addition the expander pcb contains:
Memory request button used during device addressing
Two digit LED display to show bus address and software version. A piezo sounder for use in the Tracer bus device locator.
Specifications
Dimensions |
230 x 144 x 44, mm HxWxD |
Weight |
0.42 kg |
Current Consumption |
20mA max quiescent. 300mA in alarm if sounder connected.
Security Grade |
3 |
Environmental |
Class II |
Operating temperature |
-10 to +55 C |
Outputs |
Open collector transistor. |
