Number of on-board zones
8
EOL resistor
Dual 4k7 (default), other resistor combinations configurable
Number of on-board relays
2 (single-pole changeover, 30 VDC / max. 1 A resistive switching current)
Interfaces
X-BUS (in, out, branch)
Tamper contact
Front spring tamper
Mains voltage
230 VAC, + 10%/ -15%, 50 Hz
Operating current
Max. 117 mA at 12 VDC (all relays activated)
Quiescent current
Max. 77mA at 12 VDC
Output voltage
11-14 VDC in normal conditions (mains powered and fully charged battery)
Auxiliary power (nominal)
Max. 1500 mA at 12 VDC (750 mA per output)
Battery type
YUASA NP7-12FR (7 Ah), not supplied
Operating temperature
0 ~ +40 °C
Colour
RAL 9003 (signal white)
Weight
4.700 kg
Dimensions (W x H x D)
264 x 357 x 81 mm
Housing
Small metal housing (1.2 mm mild steel)
Standard / approval
EN50131-1 / EN50131-3 / EN50131-6, Grade 2, Class II
SE: SFF1014, Larmklass 2
BE: INCERT
HU: MABISZ
CZ: NBU
