Specials
Genie High Resolution Video to VGA Converter
£59.99
£53.99 Ex VAT
£53.99 Ex VAT
There are no products to list in this category.
Featured Products
£92.03
£73.62 Ex VAT
£73.62 Ex VAT
4 programmable zones Activate end of line monitoring 30 fire detectors per zone Unlimited number of call points per zone Integral manual...
£78.39 Ex VAT
* 2 programmable zones * Activate end of line monitoring * 30 fire detectors per zone...
£10.65 Ex VAT
Obsolete Memory control, remote led control, Signal count, led disable, low voltage alarm, S.P.S.T. (lb) alarm output TAKEX newly developed 4-bit...
£105.00 Ex VAT
Main Features • 1/2.8 "Panasonic COMS • Low power consumption, capture moving images without jagged edges and smear •...
£62.49
£49.99 Ex VAT
£49.99 Ex VAT
2 programmable zones Activate end of line monitoring 30 fire detectors per zone Unlimited number of call points per zone Integral manual...
£74.89
£73.13 Ex VAT
£73.13 Ex VAT
Monthly Specials For April
£114.30
£102.87 Ex VAT
£102.87 Ex VAT
Flush mount Kristallo audio apartment station. Touch sensitive controls and half duplex handsfree speech with facility for simplex speech if...
£4.19
£3.35 Ex VAT
£3.35 Ex VAT
An easy to install tool-less ADSL micro filter widely used in the alarm system industry, for new and upgrading existing alarm systems. When an...
£17.73
£14.18 Ex VAT
£14.18 Ex VAT
MODEL BA-2R/BA-2W BS-1R/BS-1W DBS-1 MA-1 DESCRIPTION BANSHEE sounder BEDROOM sounder DETECTOR BASE sounder MULTI ALERT...
£27.70
£22.16 Ex VAT
£22.16 Ex VAT
RIU-R24 Auxiliary Relay The RIU range of auxiliary relays offer a rapid and cost effective solution to applications requiring the additional...
£27.70
£22.16 Ex VAT
£22.16 Ex VAT
£1.32
£1.19 Ex VAT
£1.19 Ex VAT
Use this back box when fitting the KRA78 Kristallo apartment stations into a solid wall.
£129.99
£116.99 Ex VAT
£116.99 Ex VAT
500m Wireless Receiver The D-TECT X Receiver is a 500 metre range communication, 4 channel receiver which is expandable up to 16 channels. This...
£4.19
£3.35 Ex VAT
£3.35 Ex VAT
New Products For April
£408.66 Ex VAT
EVVA L31667 AirKey Scandinavian Proximity Security Cylinder - SKA External Nickel Plated The EVVA AirKey Scandinavian Security Cylinder is a...
£10.95 Ex VAT
* BNC Female to BNC Female Connector Missing Key Features BNC Male to BNC Male with 180mm Coaxial Cable on Both Sides No Power Required ...
£410.02 Ex VAT
EVVA L33582 AirKey Starter Package Inc Cylinder, Assembly Tool, 3x Fobs And 6 x Key Credits This AirKey starter pack contains a Euro cylinder with...
£16.65 Ex VAT
The SmartPlug is the first step in transforming the home into a more efficient and connected living space. Fully integrated with the...
£408.66 Ex VAT
EVVA L31667 AirKey Scandinavian Proximity Security Cylinder - SKI Internal Nickel Plated The EVVA AirKey Scandinavian Security Cylinder is a...
£408.66 Ex VAT
EVVA L31672 AirKey Rim Proximity Cylinder Silver The EVVA AirKey Rim Cylinder is a perfect proximity solution for doors with rim cylinders...
£270.82 Ex VAT
HKC SW10270-M Prox with Wired Keypad in A Metal Housing Product Overview Designed for larger domestic and commercial applications...
£85.00 Ex VAT
Vanderbilt IB46-MF-HD MIFARE Tag Heavy-duty(10pcs) Discontinued Product Heavy Duty MIFARE Classic 1k Tag, suitable for use with all SiPass SmartCard...
£408.66 Ex VAT
EVVA AirKey Battery Operated Proximity Key & Turn Euro Cylinder L25626 72mm 36 - T36 Nickel Plated The electronic AirKey battery...
