Honeywell Le Sucre (CAMIR-F1) Wireless PIR Sensor with Built-in Colour Camera
Reliable confirmation of alarms is becoming a more and more vital element of a security system. The CAMIR-F1 Range offers an image verifi cation solution that allows the end user or the Alarm Receiving Centre (ARC) to verify if an alarm sent by the intruder system is real or not. This allows the ARC to react to a genuine intruder signal thereby reducing false alarms and the associated costs of police penalties. Furthermore, in case of a disputed alarm, the images taken by the sensors are proof of an intrusion and can also be used by the police to trace and identify the intruder.
Colour images, low or high res
Built-in high power white LED
Compatible with the Domonial 800 and Le Sucre control panels
Pet Immunity with adjustable sensitivity
Walk-Test Mode
Camera settings can be adjusted using the DomoPc confi guration software
High performance wireless narrow band
Built-in temperature alarm sensor (54°C)
Dimensions 55 x 121 x 64 mm
