Aritech Advisor Advanced Control panel, EN grade 2, 8 - 32 zones
£129.83 Ex VAT
  • Model: ATS1000A-SM
  • Shipping Weight: 2kgs
  • Manufactured by: GE Security
 Sold Out
Alternative click here
Description
Advisor Advanced control panels
The Advisor Advanced product line is the latest offspring from the Advisor CD and Advisor Master product lines. Its heritage consists of appreciated and well-known functions and features while at the same time being prepared for the future. A future where changes in communication standards are going to provide challenges. Communications traditionally based on PSTN networks are moving towards IP or wireless communications while PSTN networks start to be discontinued. Flexibility in different communication options allows for long-term flexibility, reliability and availability. For that reason, local configuration of the Advisor Advanced products is possible through an onboard USB port.
Based on the Advisor CD user interface, it allows for a quick transition while at the same time being able to use new features in a familiar way. The quick menu browsing has returned to provide quick access to menus. Those unfamiliar have full menu browsing at their disposal. A built-in Hint key provides hint on options to reduce the time to become familiar with the menu structure.
Approvals in Europe start to converge to one standard: EN50131. The new Advisor Advanced product line is designed against EN50131 compliancy as a standard.
Using existing ATS accessories (keypads, readers, expanders) it delivers a reliable system and a large range of options to extend the functionality of the system.
  • 8 onboard zone inputs
  • Max 32 zones: wired, wireless or mixed - 4 Areas
  • Economic input and output plug-in expansion
  • Up to 16 shock sensor inputs
  • Simplified start up wizard
  • Up to 50 users - Door Access - 2 level Partset
  • EN50131 Security grade 2 / Environmental class 2
  • USB port for local configuration
  • Automatic hardware enrollment
  • Onboard PSTN dialler for reporting or configuration
  • Optional voice module, GSM/GPRS module, ISDN module
  • Optional: SMS reporting and control
  • Multilingual: each user his own language
  • Different housings
  • Auto arming - Schedules - Times Outputs
  • ATS1235 support
Technical specs
Zones
 Total zones
  32
 Max wired zones
  32
 Max wireless zones
  32
 Plug-in expansion zones
  8
Areas
 Max areas
  4
Keypads/Readers
 Min nbr of LCD keypads
  1
 Total keypads/readers
  8
Users
 Max nbr of users
  50
 Max nbr of user groups
  16
 Max nbr of cards
  50
 Max nbr of PIN codes
  50
Power Supply
 Mains power
  230 VAC +10%, −15%, 50 Hz
 Main board current consumption
  100 mA
 Max system current
  1000 mA at 13.8 V ±0.2 V
 Max aux power current
  840mA (depends on backup power needs)
Fuses
 Auto-reset
  5
 Glass break
  1 (mains power)
Data bus
 Type
  RS485
 Recommended cable
  WCAT52/WCAT54 or equivalent
Environmental
 Class
  Class II, indoor
 Operating temperature
  -10 to +55°C
 Relative humidity
  95% non-condensing
 IP rating
  30
Dimensions
 ATS1000A-SM
  250 x 250 x 86 mm
 ATS1000A-MM
  315 x 388 x 85 mm
Accepted Cards
