This is a complete kit which comes with all the components required to install a small domestic intruder alarm system. The 8 zone panel is supplied with a remote LED keypad, the bellbox supplied is for external use and incorporates a strobe and sounder. Detection devices include 2 x ESP Quest PIR's and 2 x white door contacts. Also included are a battery for backup in case of mains failure.
Kit Contains 1 x ADE Accenta Mini panel with RKP
2 x ESP Quest PIR's
2 x White door contacts
1 x AG6 Decoy
1 x AG6 blue & white external bell box
1 x 2.4Amp 12V battery
Main Features
- Up to 4 Accenta RKP’s per system
- Part set programs
- 4 access codes
- Chime
- 5 programmable outputs for Digital communicatorl 8 zones programmable
- PA input
- Tamper input
- Ouputs for external Siren and strobel 250 event memory (LCD keypad), 8 event memory (LED keypad)
- Walk test facilities
- Quick set feature
- Battery capacity of: 2.1Ah
Panel | On board keypad | No |
| Simple set interface | Yes |
| RKP indication | Yes (supplied) |
| 8 zones | +ve loop, fully programmable |
| Tamper | -ve loop |
| Bell output | 12V latching, timed 1 to 99 minutes |
| Strobe output | 12V |
| Extension speaker | Max two, 16 ohm |
| Entry / exit timers | Programmable 10 ro 990 seconds |
| Zone input delay | 300 or 800ms selectable |
| Set +ve output | Source 10mA, sink 40mA |
| CPU current consumption (standby) | 45mA |
| RKP current consumption (standby) | 25mA |
| Low voltage output | 13V +/- 5% |
| Rechargable battery | Up to 2.1Ahr |
| Communicator outputs | Yes |
| Communicator output types | Intruder, PA, abort, set |
| PCB fuses | 1 x 1.6A, 3 x 1.0A |
| Mains input fuse | 125mA anti-surge |
| Total current output | 1Amp when supported by fully charged battery |
| Mains suppy voltage | 230V +/- 10% |
| RKP wiring | 6 core. Max distance 100m |
PIR
| Range | 14m (with standard lens) |
| Angle | 110 degrees (with standard lens) |
Power consumption | 15mA at 12V DC |
| Relay | Normally closed |
| Tamper | Normally closed |
| Pulse count | 1, 2 or 3 |
| RFI immunity | 40V / metre to 1Ghz |
| Lens types available | Pet lens, curtain lens, long range corridor lens |
This product was added to our catalog on Tuesday 08 June, 2010.
