This is a complete kit which comes with all the components required
to install a small domestic intruder alarm system. The 8 zone panel is
supplied with a remote LED keypad, the bellbox supplied is for external
use and incorporates a strobe and sounder. Detection devices include 2
x Honeywell Activ8 Quad PIR's and 1 x white door contact while a 100m roll of 6
core white alarm cable is supplied for wiring purposes. Also included
are a battery for backup in case of mains failure.
Kit Contains
1 x ADE Accenta Mini panel with RKP
2 x Honeywell Activ8 18m Quad Pet PIR's
1x White door contacts
1 x AG6 blue & white external bell box
1 x 100m roll of white 6 core cable
1 x 2.4Amp 12V battery
Main Features
- Up to 4 Accenta RKP’s per system
Part set programs
4 access codes
Chime
5 programmable outputs for Digital communicatorl 8 zones programmable
PA input
Tamper input
Ouputs for external Siren and strobel 250 event memory (LCD keypad), 8 event memory (LED keypad)
Walk test facilities
Quick set feature
- Battery capacity of: 2.1Ah
Panel
| On board keypad |
No |
| Simple set interface |
Yes |
| RKP indication |
Yes (supplied) |
| 8 zones |
+ve loop, fully programmable |
| Tamper |
-ve loop |
| Bell output |
12V latching, timed 1 to 99 minutes |
| Strobe output |
12V |
| Extension speaker |
Max two, 16 ohm |
| Entry / exit timers |
Programmable 10 ro 990 seconds |
| Zone input delay |
300 or 800ms selectable |
| Set +ve output |
Source 10mA, sink 40mA |
| CPU current consumption (standby) |
45mA |
| RKP current consumption (standby) |
25mA |
| Low voltage output |
13V +/- 5% |
| Rechargable battery |
Up to 2.1Ahr |
| Communicator outputs |
Yes |
| Communicator output types |
Intruder, PA, abort, set |
| PCB fuses |
1 x 1.6A, 3 x 1.0A |
| Mains input fuse |
125mA anti-surge |
| Total current output |
1Amp when supported by fully charged battery |
| Mains suppy voltage |
230V +/- 10% |
| RKP wiring |
6 core. Max distance 100m |
PIR
| Range |
18m (with standard lens) |
| Angle |
90 degrees (with standard lens) |
Power consumption |
15mA at 12V DC |
| Relay |
Normally closed |
| Tamper |
Normally closed |
| Pulse count |
Selectable |
| RFI immunity |
40V / metre to 1Ghz |
| Lens types available |
Std |
This product was added to our catalog on Wednesday 21 April, 2010.
