Shopping Cart Item(s) 0 | Total: £0.00
Security Warehouse
Honeywell Reson8 Bell Box
£18.34
Model: 8EP420
Shipping Weight: 1kgs
18 Units in Stock
Manufactured by: Honeywell
Qty:
The Reson8 bell box brings together aesthetics and functionality in a product designed to exceed all the requirements of EN50131-4 – Security Grade 2, Environmental Class III.
With fully integrated sounder/strobe, self-activating cut-off timer and twin status indication, your choice of audible/visible warning devices has just been made easier.
Features:
  • Dual Anti-Tamper Operation:
      Tamper circuitry will operate if either the cover is opened, or the bell box is removed from the wall.
  • Integral Battery Backup:
      With the integral 12V Ni-Cd battery, SAB facility is available as standard.
  • 115dB Sounder Output:
      Once triggered, a piercing 115dB siren sounds, this together with the high-visibility xenon flashes, provides both an audible and visual indication of a break-in.
  • Fully integrated sounder/strobe
  • Twin LED Status Indication:
      Two internal LEDs, one to identify that power is being supplied, and one to indicate tamper status. LED’s can also be set to alternate for eye-catching status confirmation.
  • Sounder Timer Selection:
      Can be configured to reset itself after a preset time interval, to avoid noise pollution. An additional test mode allows short alarm bursts (lasting 5 seconds) when testing the alarm operation during commissioning.
  • Self-activating cut-off timer
£4.95
Extensive research has been carried out to discover the requirements of the electrician. This information has been carefully considered in order for...
Quest 14m PIR
£8.49
50High immunity PIR with digital pulse count. Advanced signal processing maximises detector stability.
Texecom Prestige IR
£12.23
The ShockTec with Magnetic Contact ensure double protection on opening windows and doors. The detector can be mounted vertically or horizontally,...
Rokonet ShockTec with Magnet White
£9.98
The ShockTec detectors have a reliable built-in calibration method that prevents over or under sensitive settings. Intelligent Digital Signal...
Rokonet ShockTec Shock Detector White
£217.03
The new Galaxy Dimension series is the next generation of intruder alarms from the established Galaxy range. Based on the market leading Galaxy 3...
Honeywell Galaxy Dimension 48 LCD Kit (includes Keyprox & 4 Fob)
£39.94
NOW ACCEPTS THE VERITAS EXCEL LCD REMOTE KEYPAD Best selling control panels with remote keypad. Featuring 8 fully programmable zones & accept up...
Texecom VERITAS R8 Plus
Copyright © 2013 SecurityWarehouse.
