Elmdene Grade 2 Self Powered Warning Device
The Inter range of internal sounders are designed for use in domestic applications and are available in three versions:
  • High level sounder
  • High (alarm) and low level (entry/exit) sounder with strobe
They are also available with or without an internal battery for SAB or direct operation. The sound output for all models is 110dB(A).
They have a low current consumption and feature engineer mode for silent start up.
  • Attractively designed range of Internal Sounders
  • Desirable appearance for domestic applications
  • 'Engineer Friendly' for easy installation and maintenance
  • Ideal for multiple residential installations
  • Low current consumption
  • Individual cover logo can be supplied
Full SAB option6V NiCd (150mAh)
Sound out (at 1m)110dB(A)
Input voltage10-14V dc (12V dc nom)
Standby Current15mA
Flash rate1 per second
Input voltage12V dc
Product DimensionsH x W x D: 110mm x 160mm x 40mm
  • Model: INT500S
  • Manufactured by: Elmdene
£26.05 Ex VAT
