There currently are 42 guests online.
Secured by
GlobalSign
ESP_GuardCam
ADE Accenta Mini Gen4 Starter Kit with LED Keypad, 2x Quest PIRs
£42.87
Basic Kit comprising 2 x Quest 12m PIR's and 1 x Accenta Gen4 LED Compact.
8 Zones
3 part set programs
operation
Personal attack facility
5 Digi-Outputs
New LED Keypad
The LED remote keypad operates with the Accenta and Optima Gen4 intruder systems. Up to four LED or LCD keypads can be connected to the system.
Fire Zone
250-event log
Duress Code
Chime
Can be used to select a low security chime alarm for various areas of your house, even when the main alarm is turned off. When a door is opened or a detector triggered in an area set to chime, the control panel will deliver a low-volume ‘bing-bong’ sound to alert you. This is ideal for areas that require low level monitoring.
Built-in tamper control
To protect all wiring and detectors in the system from unauthorised access including the control panel and remote keypad covers.
  • Model: 8SP400A(Quest-KIT)
  • Shipping Weight: 3kg
  • 15 Units in Stock
  • Manufactured by: ADE
This product was added to our catalog on Tuesday 20 October, 2009.
