| Firmware | V3.x |
| Programmable areas | 4 |
| Max. number of user codes | 32 |
| Wireless Panic Alarm | Up to 32 |
| Event memory | 1000 intrusion events, 1000 access events |
| Language | Multi-language support (en, de, es, it, sv, fr, nl, vls, 1 imported custom language file) |
| Number of on-board zones | 8 |
| Max. number of hardwired zones | 32 |
| Max. number of wireless zones | 32 (take away wired zones) |
| EOL resistor | Dual 4k7 (default), other resistor combinations selectable |
| Max. number of outputs | 30 |
| Number of on-board relays | 1 strobe (30 VDC / 1A resistive switching circuit) |
| Number of on-board open coll. | 2 internal / external bell, 3 freely programmable (each max. 400mA resistive switching circuit, supplied via auxiliary output) |
| Door capacity | Max. 4 entry doors or 2 entry/exit doors |
| Number of card reader | Max. 4 |
| Radio module | Optional (SPCW110) |
| Verification | 4 verification zones with max. 4 IP-cameras and 4 audio devices |
| Video | Up to 16 pre / 16 post event images (by JPEG resolution 320 x 240, max 1 frame per sec.) |
| Audio | Up to 60 sec. pre / 60 sec. post audio recording |
| Time function | 4 calendars (53 weeks, multiple on/off switching patterns for users, areas, inputs, outputs, keypads, doors) |
| Macro language | Cause & Effect programming (8 triggers & 4 mapping gates) |
| Number of field devices | Max. 11 (4 keypads, 2 door-expanders, 5 input/output expanders) |
| Interfaces | 1 X-Bus (1 spur) 1 RS232
 1 USB (PC connection)
 1 SPC Fast Programmer
 1 Ethernet (RJ45)
| Tamper contact | Front spring tamper, 2 auxiliary tamper contact inputs |
| Mains voltage | 230 VAC, +10%/ -15%, 50Hz |
| Operating current | Max. 190 mA at 12 VDC |
| Quiescent current | Max. 170mA at 12 VDC |
| Output voltage | 13-14 VDC in normal conditions (mains powered & fully charged battery) |
| Auxiliary power (nominal) | Max. 750mA at 12 VDC |
| Battery type | YUASA NP7-12FR (7 Ah), not supplied |
| Operating temperature | 0 ~ +40 degC |
| Color | RAL 9003 (signal white) |
| Weight | 4.500 kg |
| Dimensions (W x H x D) | 264 x 357 x 81mm |
| Housing | Small metal housing (1.2mm mild steel) |
