Secware Infra-Red LED illuminators emit a ray of light that is
invisible to the human eye buy easily visible to the image sensor of a
camera. The result is that the camera is able to 'see' in very low
light conditions (down to 0 LUX) up to a range specified by the power
and number of LED units.
Secware IR illuminators are available in up to 25m, up to 50m and
up to 80m versions and are designed to be bolted to the underside of a
camera housing. Ready made housing units with the illuminator already
attached are also available.
IR Count |
56
£15.82 Ex VAT The SOINT2 sounder is supplied in a sleek white low profile louvre-free housing that will blend discreetly into any surrounding. The SOINT2 HI-LO low...
£7.94 Ex VAT Obsolete Alternative Click Here Passive Video Balun BNC Male to Quick Release Terminal Block Low Profile Assembly - Ideal for DVR's Black ABS... Sold Out
£6.74 Ex VAT Description The IB44-EM is a keyring tag that is compliant with EM4102 reading technology. It can be used with the readers HD500-EM‚...
£0.88 Ex VAT DC12V Power Connector Jack (Male) To Terminal Block
£53.49 Ex VAT External PIR Detector The Elite is a passive infrared detector that simultaneously or individually controls cameras, VCR’s, DVR’s and all...
£2.94 Ex VAT CCTV Data protection Compliant CCTV Warning Sign. Size A4, A3 also available. Plastic Contruction to allow for fixing direct to the required surface
