Pyronix Deltabell E Module - Grade 3
  • Piezo sounder technology
  • 3 Way tamper action
  • Universal triggering inputs
  • Supplied with rechargeable battery
  • Engineer hold off
  • Hinged lid available - see below
  • Remote engineer hold off input
  • IP65 rated
  • Increased battery capacity
  • Siren trigger input is continuously monitored for integrity
  • Active self-test for SAB back up battery
  • Fault relay output
Product Features
FeaturesDescription
Piezo sounders with high decibel outputBelle: 118dBa. Decibell E/ Deltabell E / Deltabell Plus: 104dBA. Invincibell E, Invinicbell Plus: 104dBA
Note: The Belle, Deltabell X and Invincibell X have 2 piezos.
The Decibell, Deltabell E/Plus and Invincibell E/Plus all have 1 piezo.
3 Way tamper actionActivation from front, back, and power supply cut off ensures protection from sabotage attempts. In this situation, the siren will activate independently of the control panel.
Positive/Negative trigger inputsCan be connected to any output that is positive applied or negative applied on a manufacturer's control panel.
Universal triggering inputsCan be connected to any output on a manufacturers control panel, positive applied, negative applied, positive removed, negative removed.
Supplied with batteryComplete with a backup battery so that even in the event of an intruder sabotage, the bell box will still operate and protect the property.
Siren cut-off timerThe cut off timer is defaulted to 15 minutes to meet industry regulations.
Engineer hold off facilityWhen first powered with the tamper switch open, the sounder will not activate.
Remote engineer hold offIt is possible to disable the bell box tamper when a control panel is in the engineers menu.
ELECTRICAL
Operating voltage9-16Vdc (13.5V nominal)
CURRENT CONSUMPTION
Standby< 50mA
Alarm< 250mA
STROBE
Strobe duration100mS
DECIBEL
Output109dBA
 For use in EN50131-1 Systems
Security Grade 3
Environmental Class 4
Module Only, cover and decoy back plate required for complete unit
Cover White
Cover Black.
Cover Chrome.
Cover Yellow.
Cover Blue.
Cover Red.
Backplate Blue
Backplate Black
Backplate Red
Backplate Amber
Backplate Green
  • Model: FPDELTAE3MOD
  • Manufactured by: Pyronix
£25.22 Ex VAT
