CQR Grade 2 Aluminium Non-Resistored Roller Shutter Contact
CQR Non-Resistored Roller Shutter Contact
This roller shutter contact can be used in most security systems up to and including grade 2 as specified in EN50131-1:2006+A3:2020 and is compliant with EN50131-2-6:2008 and environmental class III.
It is designed to work with control panels that require a normally closed circuit going open in alarm and also has a 450mm of armoured cable to allow for connection to a suitable junction box. It has a single reed switch and a tamper loop, this contact can be used on roller shutter doors to detect the unauthorised entry of an intruder. The contact is potted/sealed to prevent access to the inside of the contact.
  • High Quality Alloy Finish
  • Double pole
  • EN50131-2-6 Grade 2
  • Environmental Class III
ColourAluminium
MaterialAluminium
Contact MaterialRuthenium
Commodity Code85311030
Country Of OriginUK
Height (mm)10
Width (mm)50
Depth (mm)200
Barcode5060399127653
Weight (kg)0.38
Type ofRoller Shutter
EN50131-2-6 Grade2
Tamper ProtectionInternal
EN50130-5 classClass III
IP Rating32
Temperature Range-10°C – +40°C
Contact Dimensions (mm)80 x 71 x 30
Magnet Dimensions (mm)80 x 71 x 30
Connection TypeWired
No. of Terminals4 Wire
Contact TypeNormally Closed
Wire length (mm)450
Mode Of OperationDP
Operation Axes (X, Y, Z)X, Y
Pull-in gap (X, Y, Z)mm25, 50
Pull in Gap50mm
Suitable for Double DoorYes
No of Reed Switches1
Resistor ValueNon-resistored
  • Model: RS002/ALI
  • Manufactured by: CQR
£15.12 Ex VAT
