Pyronix FPKX15DT3 15m Dual Technology Digital Detector
INDUSTRIAL / COMMERCIAL / RESIDENTIAL
  • Dual element pyro-electric sensor
  • X-band DRO based microwave
  • 15m detection range
  • Selectable EOL (End Of Line) resistors
  • AND/OR technology
  • Patented Independent Floating Thresholds (IFT)
  • Blue wave technology
  • Auto sensitivity feature
  • Digital temperature compensation
  • Triple LED indication
  • Frequency options
  • Sealed optics
  • Tamper proof brackets included
  • ABS plastics
  • Tested and Certified to EN 50131-2-4
FeaturesDescription
15m Volumetric detector15m Volumetric detection coverage. Ideal for protection of rooms, offices etc.
Selectable EOL resistorsThe KX15ED incorporates selectable alarm resistor values of 6K8, 5K6, 4K7 &1K & tamper values of 5K6, 4K7, 2K2 and 1K catering for most control panels on the market.
AND/OR technologyAND’ mode operates as a standard dual technology detector. ‘OR’ mode will switch to microwave detection in environments where there is a risk of PIR detection being blocked,
Blue wave technologyThis technology further enhances the detector’s immunity to infra-red noise in the environment. BWT comprises of 2 key components: 1). The new 3D optics system enables perfect focusing of the infra-red signal onto the pyro-electric sensor. This allows BWT to clearly identify the positive and negative signal edges. 2). Powerful software embedded into a microprocessor is used to process the received information from the pyro-electric sensor. The result of this combination is lower infra-red signal noise amplification and therefore better immunity.
Auto sensitivity featureDepending on the environment condition, the detector will automatically adjust the sensitivity
Digital Temperature CompensationWhen the product is used in a hot environment this technology digitally adjusts the detector’s sensitivity allowing it to maintain its range even when the background room temperature is almost equal to the external body temperature of 32ºC (internal body temperature = 37ºC)
Active self testIf there is no activation after a 5 hour period it will actually self test both the PIR and microwave
Triple LED indicationMicrowave - orange, PIR - green, alarm - blue. (KX15DTAM - Blue flashing = mask)
Microwave Frequencies Bands3 different frequency bands to avoid interference between detectors are installed in the same room
  • Model: FPKX15DT3
  • Manufactured by: Pyronix
Qty Discounts Off Price
1-49
£30.34
50+
£29.84
£30.34 Ex VAT
