There currently are 39 guests online.
IS215Banner
Knights Plastic Single Push Panic Attack Button
£2.09
Panic Button
This range of personal attack buttons is ideal for domestic or industrial applications where silent operation is required. The efficient double push range includes an electronic flush fitting unit with LED indication. The electronic PA is designed for reliable long term use and the standard version is compliant to BS7042.
FEATURES Single or double push * Silent operation to BS4737 part 2 * Visual indication * Key resettable * Premium 1.2mm metal used on stainless steel & brass versions * Double push stainless steel and brass versions include separate tamper * EPA can be flush fitted
Single button - High impact polystyrene
PASP1 - White
PASP1/BS - Brass
PASP1/SS - Stainless Steel
PA614/SS - Stainless Steel with bell / siren for direct drive complete with tamper
Double Button - ABS Plastic
PADP2/WH - White
PADP2 / SS - Stainless Steel, tamper
EPA/STD - Electronic Self latching PCB
Order CodeEPA STD
Voltage12 - 15Vdc
Current40 mA
Switching500mA
TamperN/C Switch
OperationInstant D.P.
ResetKey
IndicationRed LED (Alarm)
DelayN/A
New Model PA Plus
Single push (PA PLUS / SP) or double push (PA PLUS / DP), both models can have an LED fitted (PA PLUS / LED) which illuminates the button area enabling easy identification in the dark.
All models are available in plastic or stainless steel.
  • Model: Plastic Single Push PA
  • Shipping Weight: 0.2kg
  • 31 Units in Stock
This product was added to our catalog on Thursday 27 July, 2006.
