There currently are 39 guests online.
ACT_Proxiimity_Kit_Deal
Smoke Detectors
Smoke Detectors for connecting to Standard 12v Intruder alarm Systems
Apollo Apollo Series 65 12V Relay Base (For use with Series 65 Heads)
The Series 65 12V Relay Base is designed for use in both fire and security systems. For fire systems a jumper on the PCB is fitted to a 'latching'...
£8.16
Add:
Honeywell Honeywell 12v non latching detector base
ECO1000BREL12N detector base with non latching relay output (12vdc) for use with ECO1002, 1003, 1005
£8.58
Add:
Honeywell Honeywell Combination Optical / Thermal Smoke Detector (58 °C)
Low profile design Low current draw Automatic drift compensation Operates on 12 and 24VDC Systems Remote alarm test feature Easy maintenance Remote...
£15.91
Add:
Honeywell Honeywell Combination Rate-of-Rise/Thermal (58 °C)Smoke Detector
£10.38
Add:
Honeywell Honeywell Optical Smoke Detector ECO1003-A
Low profile design Low current draw Automatic drift compensation Operates on 12 and 24VDC Systems Remote alarm test feature l Easy maintenance Remote...
£10.38
Add:
Honeywell Honeywell standard 12v latching base
Standard detector base for the Honeywell ECO1002, 1003, and 1005 Latching relay output (12vdc)
£8.34
Add:
Menvier Menvier M12 4 in 1 Smoke Detector for Intruder Alarm
• Four programmable separate detection capabilities within one unit • Smoke detector compatible with all 12v alarm systems • Advanced optical and...
£22.14
Add:
Menvier MENVIER TSOS2
MENVIER TSOS2
TSOS2 This unit is now obsolete and has been replaced with the M12   Key Features   Low current, standard optical smoke detector...
£27.14
... more info
Sold Out
Texecom Texecom EXODUS RR/4W RATE OF RISE HEAT DETECTOR
Rate of rise heat detector. Suitable for use where smoke or dust is prevalent, with fastest heat detection performance. Example Usage: bars &...
£17.50
Add:
Texecom Texecom FT64/4W Fixed Heat Detector
Fixed 64°C heat detector. Suitable for use where smoke or dust is prevalent with superior false alarm immunity. Example Usage: bathrooms &...
£16.92
Add:
