Shopping Cart Item(s) 0 | Total: £0.00
Security Warehouse
Elmdene EN3-QSC Grade 3 Medium Surface Contact (Green Resistors)
£8.26
Model: EN3-QSC(GN)
Shipping Weight: 0.2kgs
17 Units in Stock
Manufactured by: Elmdene
Qty:
Surface
Grade 3
Model EN3-QSC
Elmdene Fire and Security products
Application
Cabled / Terminals Cabled
Suitable for Wood or Metal Wood or Metal
Fixing Screws
Operation Mode FSL or DP
Single / Multiple Doors Single or Multipe
Special Features Magnetic Immunity
Material ABS
Colour White or Brown
Contact Details
Magnetic Detection / Immunity Immunity
Operating Gap - Minimum Close (mm) 9
Resistors Fitted Yes
Number of Wires or Terminals 6W
Stainless Steel Cable Protection No
Encapsulation Potted
Contact Dimensions & Fixing
Length (mm) 70
Width (mm) 17
Depth (mm) 15
Flange (mm) N/A
Body Diameter (mm) N/A
Cable Length (cm) 100
Fixing Screws
Magnet Details
Length (mm) 70
Width (mm) 17
Depth (mm) 15
Flange (mm) N/A
Fixing Screws
Classification
TS50131-2-6 Grade 3
Environmental Class III
Protection IP67
ResistorsColourCodeControl Panel(s)
4K7 / 2K2Red(RD)ADE - Bosch - Castle Care-Tech - Dycon - Menvier - Pyronix - Scantronic - Texecom
1K / 1KGreen(GN)Galaxy
8K2 / 8K2Blue(BL)Guardall
4K7 / 4K7Grey(GY)Aritech - Pyronix
6K8 / 4K7Purple(PU)Gardtec / Risco
2K2 / 2K2Yellow(YL)Bosch - Europlex
£17.75
Activ8 DT - Dual Channel Quad Element PIR with Microwave Detection Features:   10.687GHz X-band doppler microwave Selectable pet immunity...
Honeywell Activ8 PIR Dual Tec
£169.52
Galaxy Ethernet Module Provides alarm signalling and remote servicing support for Galaxy systems via 10 Base T Ethernet LAN/WAN supporting TCP/IP...
Honeywell Galaxy Ethernet Module
£8.34
Standard detector base for the Honeywell ECO1002, 1003, and 1005 Latching relay output (12vdc)
Honeywell standard 12v latching base
£31.48
Low profile design Low current draw Automatic drift compensation Operates on 12 and 24VDC Systems Remote alarm test feature Easy maintenance ...
Honeywell Combination Optical / Thermal Smoke Detector (58
£7.60
Flush Grade3 ModelEN3-QFC ApplicationCabled / TerminalsCabled Suitable for Wood or MetalWood or Metal FixingScrews Operation ModeFSL or DP ...
Elmdene EN3-QFC Grade 3 Brown Flush Contact (Green Resistors)
£33.99
Z & L Bracket set  can be used with SSP EM10 Mag Lock Key Features Used on inward opening doors
SSP Z & L Bracket for Standard Magnetic locks
Copyright © 2013 SecurityWarehouse.
