Videx 8000 Series 1 Button Speaker Module
Videx 1 Button Speaker Module
8000 Series speaker modules are available for a range of Videx systems, from standard analogue up to Vx2200 digital systems. The speaker modules themselves are available with either 0, 1 or 2 buttons, and a further 62 buttons may be added using 8842, 8843, 8844 and 8845 button modules.
All modules name windows are illuminated, and contain a replaceable insert for displaying flat numbers or names.
All modules contain a speaker and fly lead with microphone which is easily fitted in to a 8000 Series frame. Modules slide in to the housing frames securing them in place.
Speech levels may be adjusted using separate controls for both the speaker and microphone.
The standard front plate is stainless steel (/S) or available in matt aluminium (/A). Housing frames are available in aluminium or black which complements the module.
  • Contains speaker and fly lead microphone (microphone easily fits within a 8000 series frame)
  • Speech volume adjustment (both directions)
  • Up to 64 functional call buttons in total
  • Available for a range of Videx systems
  • Illuminated name windows
  • Stainless steel or aluminium front plate
  • Simple but strong slide in module design
  • Power: 12Vac (8835, 8836, 8836M, 8836i)
  • Power: 8-12Vdc, 12Vac (8837)
  • Power 12Vdc (8837M, 8203)
  • Call reassurance: (8836M, 8837M, 8203)
  • Buttons max: up to 2 on speaker module
  • Buttons: Tactile microswitch
  • Systems: 8835 (1+1), 8836i (IK1S kit), 8836M (3+1 8K*S kits), 8836 & 8837 (4+1), 8837M (3+1), 8203 (Vx2200)
  • Lock output: Dry contact NO & C (8835, 8836i, 8836M, 8837, 8837M), C, NO & NC (8203)
  • Model: 8837M-1
  • Shipping Weight: 0.7 kgs
  • Manufactured by: Videx
£65.40 Ex VAT
