Eaton 8 Zone Conventional Fire Alarm Control Panel
£263.28 Ex VAT
  • Model: EFCV8ZONE
  • Shipping Weight: 2kgs
 Sold Out
Alternatie click here
Eaton’s 8 zone conventional fire system panel delivers a straightforward, intuituve interface that makes programming and maintenance simple.
Approved to EN54-2&4, it offers a comprehensive set of functionalities in a modern, robust and discrete enclosure. It’s appearance and performance makes the panel well suited for life safety notification in a wide variety of small to medium sized buildings, particularly schools, warehouses, retail stores and office buildings.
With the addition of an isolator barrier the panel has the additional flexibility to monitor standard or intrinsically safe conventional zone circuits, making it suitable for industrial applications.
• Zones switchable between standard conventional and intrinsically safe zones (using isolator barrier)
• One man test facility
• Class change input
• Supports expansion card for Fire Routing Equipment, Fire Protection Equipment and fire relays per zone
• Modern and discreet enclosure
Code:  EFCV8ZONE
Description: 8 Zone Conventional Panel
Input Voltage Range: 18.75 - 30.7V
Maximum Current Drawn From Battery: 2.7A
Number of Zones: 8
Maximum Loading Per Zone: Standard Mode: 32 detectors and manual call points
Intrisically Safe Mode: 10 detectors and manual call points
Standby Zone Voltage (Vmin - Vmax): 19Vdc - 23Vdc
Alarm Zone Voltage (Vmin - Vmax): 31Vdc - 33Vdc
Fuse Protection Per Zone: 250mA PTC
End of Line A Termination: Standard Conventional Zones - EOLM-1 Only
Intrinisically Safe Zones - SKI Resistor
Number of Sounder Circuits: 230V Ah +10%/-15% 50Hz
Maximum Loading per Circuit: 250mA
Fuse Protection per Circuit: 250mA PTC
End of Line B Termination: 6K8 Resistor
Unmoniroted Outputs - Fire, Fault, Interlink Relay: Type - Volt-Free, Single Pole Double Throw
Rating - 30Vdc, 1A
Fuse - 500mA PTC
Auxilliary Output: V - 18.15-30.7V
Imax - 50mA
Fuse - 50mA PTC
Unmonitored Inputs: Class Change Open Circuit - Normal Panel Operation
Short Circuit - Activate All Sounders
Repeater Port (use of this port is outside the scope of EN54): Type - RS485
Nodes - 1
Operating Temperature: -5°C to +40°C
Relative Humidity (Non-condensing): 93% +/-3%
IP Rating: IP30
Dimensions (WxHxD): 375mm x 366mm x 134mm
Weight (excluding batteries): 2.25Kg
Materials: PC ABS Front and Rear
Standards: EN54 Part 2 CIE & Part 4 PSE, BS5839 Part 1
Accepted Cards
