This sounder has been
fully approved to EN 54-Part 3 by the LPCB and VdS on tones 1, 8, 11, 25
and 27.
All the standard features are retained
including the facility to select from three volume settings via the DIL
switch. This allows individual sounders to be retro-converted to high
output devices where additional sound output is required.
Tones are selected via the DIL switch on the
PCB. By using 3-wires, a second stage alarm may be switched so that the
second tone will over-ride the selected tone.
Standard with all VTG products is a universal
locking system. Utilising an industry standard grub screw, each VTG
product may be locked in place, making VTG fully compliant with the
latest requirements of British and European standards.
Quick fit mounting is achieved by the bayonet
fixing arrangement on each base and is standard on both base variants.
The deep mounting base features a throw-away cover plate for surface
mount wiring. This is kept in place when wiring directly through into
the rear of the product.
| Part No. |
VTG-32-SB |
VTG-32-DB |
| Sound Level: |
Low |
Med |
High |
Low |
Med |
High |
| Sound Output @ 1
metre Tone 1 |
86dBa |
101dBa |
106dBa |
86dBa |
101dBa |
106dBa |
| Current
Consumption @ 24Vdc |
≤ 9mA |
≤ 18mA |
≤ 36mA |
≤ 9mA |
≤ 18mA |
≤ 36mA |
| Voltage Range |
21.6 - 28Vdc |
| Number of Tones |
32 |
| Operation
Frequency |
440Hz - 2900Hz |
| IP Rating |
IP21C |
IP33C |
| Temperature Range |
-20
For more information, please visit this product's datasheet.
