The 6400 Series from Videx, a low cost, easy to use, compact, minimalistic design hands free colour videophone.
Finished in a satin white and including a 4.3” high definition LCD TFT colour display and four tactile buttons for door release, door recall and other services such ‘do not disturb’ and service buttons depending on the model.
The door open and privacy functions are also accompanied by an indication LED (The door open LED requires an additional connection).
A picture brightness control and call tone volume adjustment is also available to the user while additional adjustments for picture contrast, hue and on some models microphone volume are available for the installer.
The 6400 Series videophones are low profile surface mount units containing all the electronics within the body of the unit and all termination connections on convenient plug type connectors for ease of installation.
Models available are:
[6458] For CVK4K, CVK8K and CVR4KV range of video kits.
[6478] For Videx VX2200 6 wire bus digital system;
[6488] For Videx VX2300 2 wire bus digital system and CESVK range of video kits.
Surface mount hands free intelligent videophone incorporating a 4.3” Hi-Res full colour active matrix LCD monitor, with “answer/camera recall”, “door open/concierge call”, “privacy” and one “service” button plus 2 LED’s* one for generic use (door opening usually) and one to indicate privacy service enabled.
Programmable settings: video mode (coax or balanced), privacy duration, melody and number of rings.
Adjustments: call tone volume (3 levels), speech volume, picture hue, contrast and brightness.
Table desktop kit for 6400 Series videophones complete with cable and wall socket also avaliable [64931]
