Videx 4 Button Audio VR Panel for VX2200
£163.96 Ex VAT
  • Model: VR120/138-4
  • Shipping Weight: 1kgs
  • Manufactured by: Videx
  • Online
Qty:
Description
The addition of proximity reader cutout to the panel includes an industry standard 40mm square cutout with studs at 49mm square. Reader options available include a Wiegand 26/34 bit reader, a Vprox reader, a PAC reader, a KMS reader or can be supplied with just the cutout for other third party readers.
The VR120 door panels (All 120mm wide) have CALL PROGRESS LEDs for “SPEAK”, “DOOR OPEN” and “BUSY” along with distinct audio reassurance
tones to assist the visitor. Buttons are IP68 rated with the option of a yellow bezel offering a high contrast to the fascia for DDA (Disability Discrimination Act) requirements.
All face plates are deep engraved with 6mm in-filled black characters to identify each button. Optional colours for specific applications can be specified along with custom logos.
The VR120 face plates are attached to their back box with either 4 or 6 anti-vandal fixings depending on panel size and options.All face plates are fitted
with a purpose manufactured neoprene seal to prevent the ingress of dust and liquid.
Audio amplifiers and microphones are protected with a fine offset stainless steel mesh to protect against vandalism.All speakers have Mylar cones to further protect against the effects of moisture.
Full control of volume levels to the amplifier and the telephones can be adjusted independently at the amplifier module, as can additional features including speech time, lock release time, reassurance volume etc.
Flush boxes are standard. Stainless steel bezel flush boxes and surface with rain shield are also available across the range. Panels and back
boxes can also be designed to specific dimensions.
  •  12 Gauge stainless steel
  •  IP68 rated buttons with optional yellow bezel
  •  SPEAK, BUSY & OPEN call progress LED’s
  •  Call progress reassurance tones
  •  Dry contact lock output
  •  Timed call, speech and lock release
  •  Speaker and microphone volume adjustments
Technical Details
Material: 12 Gauge stainless steel
Fixings: M5 counter sunk stainless steel
Speak and mic protection: Offset stainless steel mesh
Panel dimensions: See datasheet download
LED's Red-Busy, Yellow-Speak, Green-Door open
Reasurance tones: Yes
Standard box: Flush mounting 50mm deep
Optional boxes: Surface with rainshield and flush with stainless steel bezel
System: VX2200 2 wire audio, 6 wire video system (Also available for other systems)
Accepted Cards
