Videx 1 Button 4000S Surface GSM Intercom Kit
£614.78 Ex VAT
  • Model: GSM4KC-1S
  • Shipping Weight: 0.32kgs
  • Manufactured by: Videx
  • Online
Qty:
Videx, GSM4KC-1S, 1 Way 4000 Series Surface GSM Audio Kit with Codelock
Totally self contained GSM door entry systems from 1 to 12 call buttons. Requires only Sim card. Door panel, Psu and antenna included. Facilities include divert one or more (Max 5) numbers, dial in to open facility (no network charges and for up to 250 telephone numbers), signal strength checking and alarm output with text message.
Programming is by either SMS or PC software (GSMPRO software available separately). There are also auxiliary input and outputs.
A codelock can be added (/CL). The codelock has 3 codes, 2 changeover relay outputs and an override input. It can be programmed from 1-99 seconds or latching output. Systems are available up 50 button or digital.
Specifications:
  • Number of entrances - 1
  • Lock output - Dry contact (C, NO, NC)
  • Auxiliary output - Open collector
  • Dial in to open numbers - 250
  • Divert calls per button - 1 to 5 numbers each
  • Power supply - 12Vdc
  • Quad band
  • Programming methods - SMS or PC
  • PSU model - 324
  • Amplifier module - 4810N
  • Expandable to 50 buttons
  • Codelock - 4800
Accepted Cards
