£40.95 Ex VAT
Chicklets for PowerMaster Small and easy to use, these proximity tags can be placed on a keychain for easy access to the premises. The user simply...
£3.85 Ex VAT
Optional DB-12 base allows any of the Fireline detectors to be used with Hardwire Intruder Alarm Systems. Depth 28mm Discontinued while stocks last
£34.19 Ex VAT
Premier Elite Flasher Interface For use with a PC and the Premier Flasher software The Premier Elite Flasher Interface can be used to update the...
£7.80 Ex VAT
The Handy Little Relay 12 volt Module is a simple-to-fit unit for use wherever dry contact, voltage free switching is required or where there is a...
£16.34 Ex VAT
Conventional Fire Alarm Detectors These Fireline detectors have been developed to provide a perfect compliment to the Fireline MAG...
£5.52 Ex VAT
Size 94mm x 40mm x 25mm Terminals 9 including 2 tamper connections Tamper Switch Spring...
