- All
- Dual Technology
- Movement Detector Brackets
- Pet
- Standard PIR's
- Wireless Movement Detector
£12.00 Ex VAT
Low Cost Proximity Tag for Texecom Premier Intruder Panels PS1 - TEXECOM PREMIER COMPATIBLE PROXIMITY TAG Compatible 30mm all-black...
£98.24 Ex VAT
The new Diamond White option for the FMK and SMK keypads is manufactured from die cast metal with a high-gloss, neutral white finish, ideal for...
£11.00 Ex VAT
Obsolete-available while stocks last Alternative click here Texecom Premier Elite QD - Quad PIR Quad element digital PIR with interchangeable...
£77.08 Ex VAT
Premier LCD keypad with Built in Proximity Tag [DBC-0001] A range of high performance LCD and LED keypads featuring intuitive...
£0.44 Ex VAT
Texecom Wall Or Ceiling Bracket For The Prestige & Premier Range Pir Detectors AFU-0004 Wall / Ceiling Mounting Bracket for Texecom...
£8.17 Ex VAT
Double Push Panic Button Latching Stainless Steel Dimensions : 91mm x 63.5mm x 29.mm Environmental Class: 2 Latching Black ABS Stainless Steel Fascia...
