- All
- Dual Technology
- Movement Detector Brackets
- Pet
- Standard PIR's
- Wireless Movement Detector
£22.48 Ex VAT
Discover a new level of excellence with the Odyssey 4 from Texecom. Stunning low profile aesthetics conceal advanced microprocessor technology, IP65...
£11.47 Ex VAT
£12.41 Ex VAT
Reliable cost effective surface mount PIR with sealed optics. 12m Volumetric Coverage Interchangeable Lens Library EN 50131 Grade 2 Adjustable...
£77.08 Ex VAT
Premier LCD keypad with Built in Proximity Tag [DBC-0001] A range of high performance LCD and LED keypads featuring intuitive...
£12.00 Ex VAT
Low Cost Proximity Tag for Texecom Premier Intruder Panels PS1 - TEXECOM PREMIER COMPATIBLE PROXIMITY TAG Compatible 30mm all-black...
£3.33 Ex VAT
Texecom Extension Loud Speaker Features: 16 Ohm 12 Watt Sound output up to 100dB Compact ABS enclosure in white 12VDC Dimensions: H 57mm x W...
