- Access Control Ancillaries
- Access Control Kits
- Audio
- Automation
- Cards / Fobs / Tags
- Digital Keypads
- Door Loops
- Magnetic Swipe
- Mechanical
- Modular
- Proximity Readers
- Request to Exit (RTE)
- Video
- Wireless Access Control
£17.95 Ex VAT
Push to Exit Button [RTE] - Request to Exit Exclusively designed by RGL for surface or flush fitting. Green Domed Button with protective collar ...
£7.80 Ex VAT
The Handy Little Relay 12 volt Module is a simple-to-fit unit for use wherever dry contact, voltage free switching is required or where there is a...
£109.12 Ex VAT
Stainless Steel, Weatherproof Magnet, Dual Voltage 12/24 VDC, With Monitoring Maglock Key Features Weatherproof Lock monitoring Dual voltage ...
£156.00 Ex VAT
The K42 codelock is the best-selling codelock in the world. It has the capacity of two 4-digit codes. One code can be used by residents or employees,...
£15.15 Ex VAT
£22.92 Ex VAT
Triple pole resettable break glass with adjustable sounder and Bi-colouredLED’s. Surface mount with cover. Details Triple pole Resettable...
