SSP Midi Magnetic Lock monitored
£76.11 Ex VAT
  • Model: EM07
  • Shipping Weight: 4kgs
  • Manufactured by: SSP
  • Online
Qty:
Midi Magnet, Surface Mount, Monitored, Standard Fixing 12V/24VDC.
Voltage Tolerance: 15%
Current Draw:
500mA @ 12Vdc 250mA @ 24Vdc
at temperature 20
Operating Temperature: -10~55 14~131
Humidity: 0~95% non-condensing.
Lock's surface Temperature (when the power is on):
current temperature +20
Holding Force: Up to 800 lbs 363 Kg
Dimensions:
Magnet:(L) 265, (W) 52, (D) 29 mm
Armature Plate:(L) 185, (W) 45, (D) 14 mm
Special Finishes for magnet and armature plate: Zinc
Epoxy Potting Compound: E87252 (S), UL94V-0
Weight Approx. : 3.0 Kg
Patent NO.: 119147
Texecom Ricochet Premier Smart Keyfob
£29.60 Ex VAT
Texecom Ricochet Premier Smart Keyfob Mesh Network Wireless Technology Remote arm, part arm and disarm Alarm System Status Display Typical 2 to 3...
 More Info
RGL Push to Exit Stainless, Surface Mount
£17.95 Ex VAT
Push to Exit Button [RTE] - Request to Exit Exclusively designed by RGL for surface or flush fitting. Green Domed Button with protective collar ...
 More Info
Texecom Premier Elite Odyssey 5/5E Compact White/Blue Cover
£7.39 Ex VAT
White and Blue cover for Odyssey 5 and 5E Compact backplates Minimum order 40 for silk screening. NB if order for screening please contact to advise...
 More Info
Knight Pass Keyswitch - Diecast Aluminium, Tampered (76)
£17.32 Ex VAT
Knight Pass Key Switch - Diecast Aluminium, Tampered Environmental Class 3 Dimensions 90x38x30mm Material - Diecast Aluminium Microswitch Tamper...
 More Info
SSP Z & L Bracket Set for Midi Magnet
£58.73 Ex VAT
Z&L Bracket EM850ZL Key Features
 More Info
CQR Surface Green Call Point Double Pole
£14.49 Ex VAT
FP3 Surface Call Point Green - Double Pole [FP3/GR/DP] A  FP3/GR/DP is unique manual call point, with high visibility LED, and which includes...
 More Info
Accepted Cards
