Application
The TB25 range of drop bolts represent true engineering innovation, design excellence and the superior quality customers have come to expect and demand from Trimec®. Designed for use on swing-through, double action doors, these drop bolts are ideal for applications where an electric strike is impractical.
Specification
High Security. Bolt is deadlocked in the extended position
Bolt position monitored
Door position monitor with integrated magnet into the strike plate (no need to install a separate reed switch)
Multiple orientation, drop bolts will work horizontally or vertically
Power to Lock/ Power to Open
Continuously Rated Solenoid
Tamper Proof. Lock cannot be defeated by slipping a metal object between lock and striker plate
Intelligent Electronics. These intelligent bolts will attempt to re-close the bolt 8 times, allowing time for swing through doors to settle in the closed position
Thermal Protection. In the event of solenoid overheat, a thermal fuse will operate, eliminating any fire risk
CE marked to EMC Directive
Finish
Standards
Voltage 12 or 24Vdc
Current (Start) 1100mA @ 12V, 1000mA @ 24V
Current (Holding) 210mA @ 12V, 90mA @ 24V
Holding Force 1000kg
Locking Mode PTL & PTO
Dimensions (Mortice) 164 x 22mm
Bolt Length 12.7 x 16mm
Faceplate Size 10 x 25mm
Monitoring Contacts Bolt & Door
