SECWARE 24 way Junction Box
£3.30 Ex VAT
  • Model: J24
  • Shipping Weight: 1kgs
  • In StoreOnline
Qty:
J24
  • Environmental Class 2
  • Material: HIPS
  • Colour: White
  • Terminals: 24 choc block + 2 tamper
  • Temp Range: -40C to 50C
  • Tamper: TACT
  • Switch Size: 125x100x48mm
  • Access: 4 End Knock-outs 6 Back Holes
HKC Plug-on Dual Path GSM & WiFi Unit for use with SecureComm
Login for price
Plug-on Dual Path GSM & WiFi Unit for use with SecureComm The GSM-WiFi unit offers dual-path connectivity via SecureComm (our cloud based...
 More Info
Genie HD-AHD/CVI/TVI Passive Video Balun Kit TX+RX With Pigtail
£5.24 Ex VAT
HDUBKITE HD-AHD/CVI/TVI Passive Video Balun Kit: TX+RX With Pigtail The HDUBKITE is a 1 Channel HD Analogue Video Passive UTP Balun. It transfers 1...
 More Info
Elmdene Large Surface Plastic with Resistor (Green)
£8.23 Ex VAT
Elmdene has an extensive range of high quality Surface Magnetic Contacts providing a choice of both 'Cabled' or 'Terminal' Contacts...
 More Info
HKC Pet Lens
Login for price
Product Overview The Pet-Lens has been designed for products using quad-element pyro-detectors, i.e.  PIR-Q ,  RF-PIR , ...
 More Info
Knight Surface G3 SS Final Push to Set Switch With LED
£20.12 Ex VAT
Obsolete Alternative click here Surface G3 Stainless Steel Final Exit Set Switch With LED Dimensions: 38mm x 90mm x 30mm Environmental Class 3 IP65...
 Sold Out
 More Info
Genie DC12V Power Connector Jack (Male)
£0.88 Ex VAT
DC12V Power Connector Jack (Male) To Terminal Block
 More Info
Accepted Cards
