SECWARE 16 Ohm Internal Speaker
£4.21 Ex VAT
  • Model: TS443-16
  • Shipping Weight: 0.6kgs
  • Online
Qty:
Small boxed 16 Ohm internal extension speaker. For use with Control panels with 16 Ohm speaker outputs. Ideal for internal sounders and entry exit tones
16 Ohm Extension Speaker
Dimensions:  110H x 110W x 55D
Minimum Sound Pressure: 92Db at 1m
Texecom Premier Elite 168 Control Panel
£224.85 Ex VAT
A complete range of commercial grade, expandable, communicating control panels featuring integration compatibility with leading access control, CCTV,...
 More Info
Texecom Odyssey 3E Complete Sounder with Cover
£29.09 Ex VAT
Odyssey Series 3/3E   Stylish hexagonal design external sounder and strobe unit.   109dB Volume IP44 Environmental...
 More Info
Eaton i-onG2SM - Expandable control panel
£146.46 Ex VAT
The i-onG2SM is a Grade 2 control panel that has 50 FSL (Fully Supervised Loops) zones, expandable up to 50, providing a reliable and constant...
 More Info
Enersys 12v 7.0 A/h Battery
£15.35 Ex VAT
 More Info
Texecom Premier 8 Zone External Expander Boxed 8XP
£54.98 Ex VAT
Premier Elite 8XP - 8 Additional Outputs [CCB-0001] CCB-0001 is a Remote Zone Expander for use with the Premier Elite Series. Features: Premier...
 More Info
Texecom Premier LCD Keypad with Prox
£77.08 Ex VAT
Premier LCD keypad with Built in Proximity Tag [DBC-0001]  A range of high performance LCD and LED keypads featuring intuitive...
 More Info
Accepted Cards
