Samsung 960hr Time Lapse VCR
Recording functions
Alarm recording : When an alarm signal is received, the recording mode is automatically switched to 3hr mode.
Repeat recording : During recording the tape reaches at its end, it is automatically rewound to the beginning and the recording is re-started.
In/Out connectors to extend the total recording time.
Program recording : With this function, the user can preset to either weekly base or daily base. In weekly recording mode, 10 events a week can be programmed. Daily recording mode enables a recording to be made at everyday same time.
1-shot recording : When time mode set 000H and this function is selected, the user
can record one frame every 1/2/3 minute.
Wide variety of recording modes
3hr to 960hrs (40days)
High quality recording
Clear and natural picture : Over 300TVL in color and 350TVL in B/W
Field recording/Field advanced playback : By using these functions, the user gets twice recorded information that can be attained with the conventional frame recording.
Audio recording and playback : Audio signal can be recorded at 3H/L12H/L24H recording modes.
Reliability & Safety
Record lock function : When this function is selected, no button can be entered. With this function, the user can keep from mishandling of the unit.
Power loss memory : By using this function, the user can check power failure and recovery time.
Record check : When "REC CHECK" button is pressed the tape is rewound for 2~3 seconds and the playback. With this function, the user can check the recording quality. Operating time check : The operating time of the unit can be checked for timely maintenance.
Easy Operation
On-Screen Display menu : By using OSD, the user easily sets time, recording mode and so on.
JOG/Shuttle : The user easily adjusts the playback speed with the shuttle and search for an image field by field with the JOG.
Built-in Time/Date generator : It allows time and date information to be superimposed onto incoming video signals.
Power requirements AC 100 - 240V 50/60Hz (
Power consumption 16W
Operating temperature 5C ~ 40C (41F ~ 104F)
Operating humidity Less than 80%
Video signal PAL
Recording system Double-azimuth rotary 4-head
helical scanning system
Tape speed 33.35mm/sec. (3H mode)
Video input 1.0Vp-p, 75ohm, BNC type
Horizontal resolution Color : more than 300TVL
B/W : more than 350TVL
Video S/N 45dB (2H mode)
Audio Recording mode 3H, 12H, 24H
Audio input -8dBm, Phono jack
Audio output -8dBm, Phono jack
Terminal inputs Alarm, Alarm Reset, Series, 1-Shot Rec.
Terminal outputs Alarm, Trigger, Tape End, Series
