Specials
Dantech Quad Relay
£24.44
£19.55 Ex VAT
£19.55 Ex VAT
Key Products
Products stored in the Main Warehouse
£1.92 Ex VAT
5-Terminal Flush Single Reed Contact (Quickfit) Colour: White Environmental Class 2 Operating Gap: 14mm (approx) Dimensions: 20mm dia Terminals : 5-...
£0.18 Ex VAT
Intended primarily for use in domestic plugs but may also be installed in appropriate single-phase installations with fault levels up to 6kA,...
£0.11 Ex VAT
Sec Ware 6 core cable available by the metre Very flexible cable, used for the cabling of intruder alarms and other low voltage systems White 6 core...
£2.68 Ex VAT
Environmental Class 2 Material : HIPS Colour: White Terminals : 8 + 2 Temp Range: -40C to 50C Tamper: Leaf Size: 70x56x20mm Access: 8 End Knock-outs...
£8.73 Ex VAT
2.1 A/h replacement General purpose Genesis NP batteries are designed using proven gas recombination technology which removes the need for...
£3.99 Ex VAT
Elmdene Graded contacts are manufactured to include EOL resistors for higher security and graded apllication
£4.19
£3.35 Ex VAT
£3.35 Ex VAT
An easy to install tool-less ADSL micro filter widely used in the alarm system industry, for new and upgrading existing alarm systems. When an...
£1.09 Ex VAT
D20 5-Terminal Single Reed Surface Contact White Colour: White Environmental Class 2 Operation Gap : 20mm Approx Dimensions: 67mm x 14mm x 13mm...
£0.93 Ex VAT
£0.99 Ex VAT
A40 5-Terminal Flush Single Reed Contact (Quickfit) Colour: White Environmental Class 2 Operating Gap: 14mm (approx) Dimensions: 20mm dia Terminals :...
