Honeywell SP20ST Indoor Siren Grade 2
£19.95 Ex VAT
  • Model: SP20ST
  • Shipping Weight: 0.5kgs
  • Manufactured by: Honeywell
  • Online
Qty:
Alternative click here
Description
EN50131-4: 2009 Security Grade 2 Environmental Class II certified indoor siren.
Versatile and reliable with a modern and attractive design.
  • Sound:
    The SP20ST indoor siren generates 94.4 dB at a distance of 1m and can be programmed to work with a montone or bi-tonal frequency
  • Application:
    Suitable for local signalling (not valid for fire alarms)
  • Robust:
    The quality of the ABS plastic box and Mylar cone speaker protection ensures high reliability and durability of the siren
  • Versatile mounting:
    The design of the mounting surface facilitates installation in a wide variety of configurations
  • Easy connection:
    The SP20ST is an integrated siren that connects directly to the bell output of any panel
  • Attractive and discreet:
    The colour and texture of the cabinet has been designed to blend with the colours and types of most common wall surfaces
Yuasa NP7-12
£15.15 Ex VAT
 More Info
Texecom Connect SmartCom Ethernet and Wifi CEL-0001
£71.15 Ex VAT
 More Info
Pyronix V2 TEL PSTN Speech Dialler with Automation Control
£91.34 Ex VAT
Obsolete  The V2 TEL is the latest innovative speech dialler from Pyronix Ltd. The speech dialler can send out alarm voice messages after an...
 Sold Out
 More Info
TEXECOM, CCJ-0001, Premier Elite PSU200XP 2.5 Amp
£119.16 Ex VAT
Premier Elite PSU200XP (2.5 Amp Switch Mode Power Supply includes Premier Elite 8XP expander)   [CCJ-0001] Energy efficient switch mode power...
 More Info
Texecom Impaq SC Wired Shock and Contact AEK-0001 White
£19.91 Ex VAT
Texecom Impaq S Wired Shock Sensor and Contact with Accelerometer Technology AEK-0001 White The new wired shock sensors are designed to detect and...
 More Info
Texecom Premier Elite Surface Mount Keypad
£98.24 Ex VAT
The new Diamond White option for the FMK and SMK keypads is manufactured from die cast metal with a high-gloss, neutral white finish, ideal for...
 More Info
Accepted Cards
