Honeywell Galaxy Dimension 48 Panel Only with PSTN Dialler
£212.58 Ex VAT
  • Model: C048-D-E1
  • Shipping Weight: 4kgs
  • Manufactured by: Honeywell
  • Online
Qty:
Galaxy Dimension GD-48 control panel with PSTN Dialler is a hybrid intruder control panel with integrated door control functionality. It is designed for mid to large commercial installations and is fully compliant to the latest PD6662:2010 and EN50131 standards.
Integrated intrusion and door control
  • Up to 8 independent protected areas
  • Up to 48 detection zones (16 zones on-board)
  • Up to 8 doors
  • Up to 100 card holders per system
  • Up to 19 Weekly schedules
  • Supports up to 8 keypads
  • Support for graphical touch-screen keypad (1)
  • Event logs for Access and Intrusion (up to 1000 each)
  • Supports several communications options (GPRS PSTN, ISDN, Ethernet)
  • Up to 8 Audio Verification (listen-in) channels
  • Single PC based central management solution
  • Enhanced interfacing protocol for system integration
  • EN50131-3:2009, EN50131-6:2008, PD6662:2010 and certified by a third party testing agency
  • Fully compatible with existing Galaxy range
Secware 6 core Intruder Alarm Cable
£11.00 Ex VAT
SecWare 100m 6 core intruder alarm cable is BS4737 compliant Very flexible cable, used for the cabling of intruder alarm and other low voltage...
 More Info
Genie Slimline UTP Passive Balun
£7.94 Ex VAT
Obsolete Alternative Click Here Passive Video Balun BNC Male to Quick Release Terminal Block Low Profile Assembly - Ideal for DVR's Black ABS...
 Sold Out
 More Info
Ventcroft High-Low sounder
£9.51 Ex VAT
 Available while stock last Obsolete Alternative Click Here Features   High Impact ABS Housing 16 Ohm Dynamic Speaker Optional...
 Sold Out
 More Info
SSP Budget Z & L Bracket for Mini Magnetic lock
£13.20 Ex VAT
Budget Z&L Bracket Set Details Used on inward opening doors Compatible with: EM02 EM05
 More Info
Enersys 12v 3.4 A/h Battery
£11.47 Ex VAT
 More Info
Enersys 12v 7.0 A/h Battery
£15.35 Ex VAT
 More Info
Accepted Cards
