GJD Opal Elite White
£62.01 Ex VAT
  • Model: GJD023
  • Shipping Weight: 0.03kgs
  • Manufactured by: GJD
  • Online
Qty:
External PIR Detector
The Elite is a passive infrared detector that simultaneously or individually controls cameras, VCR’s, DVR’s and all low voltage switching requirements.
The Elite offers a high level of adaptability. There are seven different modes of operation, giving various permutations of normally open and normally closed arrangements for the two pairs of volt-free relays, plus a selection of timing and functional options for the relay changeover contacts. Other programmable parameters include the duration of timed changeover, a pulse count feature and a choice of detection ranges from 10 to 35 metres.
Part Codes
GJD022 Elite External PIR Detector (Burgundy coloured housing)
GJD023 Elite External PIR Detector (White coloured housing)
TEXECOM, CCJ-0001, Premier Elite PSU200XP 2.5 Amp
£119.16 Ex VAT
Premier Elite PSU200XP (2.5 Amp Switch Mode Power Supply includes Premier Elite 8XP expander)   [CCJ-0001] Energy efficient switch mode power...
 More Info
Elmdene EN3 10 Way Junction Box
£2.41 Ex VAT
  Size 93mm x 25mm x 26mm   Terminals 10 including 2 tamper connections   Tamper Switch Spring operated...
 More Info
Texecom PC-Com
£22.51 Ex VAT
Texecom Serial Connector for use with Win tex and premier control panels
 More Info
Enersys 12v 18.2 A/h Battery
£36.99 Ex VAT
 More Info
SECWARE 6 way Junction Box
£0.90 Ex VAT
J40 Environmental Class 2 Material : HIPS Colour: White Terminals : 6 + 2 Temp Range: -40C to 50C Tamper: Leaf Size: 78x24x22mm Access: 2 End...
 More Info
Texecom Prestige External TD Outdoor Motion Sensor Black
£77.15 Ex VAT
Texecom AFQ 0001 Premier External TD Outdoor Motion Sensor Black   Texecom’s philosophy of innovative design is perfectly captured...
 More Info
Accepted Cards
