- Cables
- Call Points
- Fire Ancillaries
- Fire Kits
- Fire/Smoke Detectors
- Panels
- Rafiki
- Sounders And Bells
£12.26 Ex VAT
Heat detectors may be used in areas where smoke detectors will suffer from false triggers due to dust or fumes arising from the use of the area, The...
£11.00 Ex VAT
Obsolete-available while stocks last Alternative click here Texecom Premier Elite QD - Quad PIR Quad element digital PIR with interchangeable...
£9.19 Ex VAT
Obsolete Alternative click here Premier Elite IR High immunity PIR with interchangeable electronics module. Features: 15/50 Detection Range...
£4.79 Ex VAT
Gent Conventional Standard Base with Schottky Diode - 2020BSD There are 4 new bases from the new range of Gent conventional fire alarm equipment: ...
£15.15 Ex VAT
