- Cables
- Call Points
- Fire Ancillaries
- Fire Kits
- Fire/Smoke Detectors
- Panels
- Rafiki
- Sounders And Bells
Specials
KAC W4A-G000SF-K013-12 Weatherproof Call Point
£66.30
£53.04 Ex VAT
£53.04 Ex VAT
Fire Detectors, Smoke, Optical, Ionisation, Heat, Rate of Rise
£59.00 Ex VAT
An IP67 Waterproof Conventional 60°C Fixed Temperature Heat Detector with minimal standby current and high reliability. Particularly suited to...
£43.00 Ex VAT
The XP95 optical detector uses an internal pulsing LED and a photo-diode at an obtuse angle. In the event of smoke entering the chamber, the light...
£25.24 Ex VAT
The XP95 heat detector has a low air-flow resistant case for good contact between the sensing thermistor and the surrounding air. Temperature is...
£51.08 Ex VAT
The XP95 multisensor detector contains an optical smoke sensor and a thermistor temperature sensor whose outputs are combined to give the final...
£42.00 Ex VAT
£9.36 Ex VAT
Heat Detector The heat detector operates by using a matched pair of thermistors to sense heat. One thermistor is exposed to the ambient temperature,...
£5.68 Ex VAT
A wide range of compatible bases is available. Detectors fit into bases one way only, without snagging, and require clockwise rotation without push...
£32.67 Ex VAT
The Discovery Optical Smoke Detector works using the light scatter principle and is ideal for applications where slow-burning or smouldering fires...
£51.72 Ex VAT
DP721R - 700 Series Conventional Optical Smoke Detector w/ Relay Output Description The DP721R is an optical smoke detector with field...
£12.21 Ex VAT
C-TEC, C4403A2, ActiV Class A2 Standard 60ºC Fixed Temperature Heat Detector ActiV Class A2 Standard (60ºC) Fixed Temperature Heat...
£39.95 Ex VAT
Gent S4-715 Optical Detector Only For the base please order Gent S4-700 Detector Base A new concept in fire detection – a truly...
£5.67 Ex VAT
Gent S4-700 Detector Base The S4-700 Gent Vigilon Detector Base is the common detector base for the Gent S-Quad range of analogue...
