Eneo High Res External Camera 540TVL 6-50mm Lens
£222.08 Ex VAT
  • Model: Eneo VKC-1327AW3-650
  • Shipping Weight: 1.2kgs
  • Manufactured by: Eneo
Qty:
- Weatherproof Camera with Swivel Head Bracket
- 1/3" Day/Night CCD Camera with Varifocal Lens
- Built-in Lens F1.6/6-50mm with DC Iris Control
- Sensitivity: 0.15Lux at F1.2 (AGC-Turbo, B&W)
- Resolution of 540 Horizontal Lines
- Removable IR Cut Filter
- Automatic Shutter Control (AES)
- Back Light Compensation (BLC)
- Supply Voltage: 12VDC
- Fully Hidden Cable Routing
- Protection Rating: IP67
- Certified according to BGV Kassen
Sensor size W3 Plug & Play
Imager CCD, Sony Super HAD Interline Transfer CCD
Active picture elements
Approx. 440,000 (H) 752 x (V) 582 pixels
Horizontal resolution 540 TVL
Gamma correction 0.45
Sensitivity (at 50% video signal) 0,5 Lux, (0.32Lux) at colour, 0.24Lux (0.15Lux) at B&W at F1.2 each (AGC-Turbo). Videor measurement result
Backlight compensation BLC, Center weighted (On/Off switchable)
Lens F1.6 ~ 270/6.0 ~ 50mm with galvanometer driven iris, manual Zoom/Fokus adjustment
Focal length 6 mm - 50 mm
Iris control DC
Mounting Wall or Ceiling*)
Protection rating IP67
Housing Outdoor
Hidden cable management Yes
White balance 2500 ~ 8000K, Automatic tracking
IR cut filter Motorized, switchable filter. Automatic function depend on the amount of light. Manual switching: see "Day/Night switching". In removed filter position, the colour signal will be switched OFF
Digital Noise Reduction (DNR No
Supply voltage 12VDC, 24VAC, (10.5 ~ 30VDC, 12 ~ 29VAC)
Power consumption approx. 5,0watts
Various RG59U/100
£18.50 Ex VAT
100m of RG59U solid core coaxial cable (solid copper)
 More Info
Accepted Cards
