Specifications: |
Operation mode | triplex |
Video standard | PAL/NTSC (automatic selection) |
Video inputs (amount) | 4 |
Video inputs | 4x 1Vp-p, (C)VBS, BNC (75ohms termination or loop-through) |
Main exits | CVBS, VGA |
Video outputs | 1Vp-p (C)VBS, (PAL: 50 Fps., NTSC: 60Fps.), 75ohms, BNC VGA |
Spot monitor | CVBS |
Audio inputs | no |
Alarm inputs | 4 inputs NO/NC, selectable |
Activity detection | Programmable 16x12 (192) masking grid, 4 levels of sensitiviy |
Alarm outputs | NO/NC contact |
Max. recording resolution | 720 x 288 (PAL) |
Compression standard | JPEG-2000, (Recording), H.264 (Network streaming) |
Image size | Basic: 14kB, Normal: 19kB, Enhanced: 24kB, Fine: 29kB, Super fine: 32kB (at 720x288 Px.) |
Max. recording rate | 200HB/Sek. |
Recording speed | 200 Fields/sec. at 360x144 Px., 100 Fields/sec. at 360x288 Px., 50 Fields/sec. at 720x288 Px. (PAL) |
Digital storage media | SATA HDD, Built-in CD-RW |
Max. harddisk capacity (internal) | 1000GB |
Harddisk capacity (internal) | 250GB |
Playback | Full, 4-channel split, PIP, Sequence, Digital Zoom, Frozen picture (in Live mode) |
Zoom function | 2x |
Intergrated writer | CD |
Secondary Storage | 2x USB 1.1 A&B interface, CD writer. Network data export: AVI & JPG |
Control units (external) | remote control, mouse |
Remote access | remote software |
Remote Software | Available (supplid with the unit) |
Search function | via timet, data and event (by Jog Shuttle) |
Menu languages | German, English, Spanish, French, Italian, Portuguese, Dutch, Danish, Estonian, Lithuanian |
Ethernet interface | 10Base-T/100-Base-TX, RJ-45 |
Interfaces external storage | USB |
Backup | USB Stick up to 2GB |
Serial interfaces | RS-232, RS-485, (PTZ control), RS-232C (PC) |
Security | Key lock, 64 user groups access rights programmable for each group (up to 256 user) |
Supply voltage | 100VAC~230VAC, 50/60Hz |
Power consumption | 80watts |
Temperature range (Operation) | +5
£7.88 Ex VAT TEXECOM ODYSSEY 3 COVER WHITE Minimum order 40 for silk screening. NB if order for screening please contact to advise via our ticket support system,...
£16.50 £14.85 Ex VAT Obsolete - Avaliable while stocks last Alternative Click Here Genie - 4-Channel Video Transceiver 4 x BNC to 1 x RJ45 and 1 x 8 Way Terminal Strip,...
£33.32 Ex VAT Texecom AGB-0001 Exodus 12v Optical Smoke, Heat Multisensor Product Overview With a range of different detection and alarm criteria, the...
£7.94 Ex VAT Obsolete Alternative Click Here Passive Video Balun BNC Male to Quick Release Terminal Block Low Profile Assembly - Ideal for DVR's Black ABS... Sold Out
£4.21 Ex VAT Small boxed 16 Ohm internal extension speaker. For use with Control panels with 16 Ohm speaker outputs. Ideal for internal sounders and entry exit...
£22.20 Ex VAT Odyssey Series 3/3E Stylish hexagonal design external sounder and strobe unit. 109dB Volume IP44 Environmental...
