Elmdene Quartz 1000 G3 External Sounder Back Plate & Cover
£29.68 Ex VAT
  • Model: QTZ-1000-G3-WB
  • Shipping Weight: 1kgs
  • Manufactured by: Elmdene
 Sold Out
Discontinued Product
Available while stocks last
The Quartz range of external sounders has been upgraded to fully meet the requirements of EN50131-4:2009 Grade 2 and 3, supporting the new functional and operational features now required.
The units are stylish and hard wearing. The outer cover and backplate are made of durable solid coloured polycarbonate. The electronics module is fully enclosed and conformal coated to provide additional protection from harsh environments.
  • Designed to meet the requirements of EN50131-4:2009 Grade 2 and 3
  • Unique, modern shape
  • Environmental class IV
  • Long working life
  • Twin comfort LEDs
  • Easy installation and maintenance
  • Low current consumption, standby and alarm
  • Replaceable internal battery
  • Ring line monitoring (G3)
  • Selectable cut-off timer
  • Selectable SAB/SCB operation (G2)
  • 24 hour self-test of battery and piezo (G3)
  • Fault output (G3)
  • Audible tamper tones for ease of commissioning (G3)
  • Internal diagnostic LED (G3)
  • Engineer mode for quiet installation
  • Front and rear tamper detection
  • Screen printing available
  • 3 year warranty
Specifications:
Part No Grade No of Piezos Sound Output at 1M Dimensions
Quartz 3000-G2 2 2 108dB(A) 292 H x 232 W x 68 D
Quartz 1000-G2 2 1 105dB(A) 292 H x 232 W x 68 D
Quartz 3000-G3 3 2 108dB(A) 292 H x 232 W x 68 D
Quartz 1000-G3 3 1 105dB(A) 292 H x 232 W x 68 D
All Sounders comply with the following standards:
  • PD 6662:2010
  • EN50131-1:2006
  • EN50131-4:2009
  • EN61000-6-3
Honeywell Galaxy Four-button compact two-way keyfob
£62.50 Ex VAT
  Four-button compact two-way keyfob   Features: Rolling code encryption Feedback on all action System status on request Warning in...
 More Info
Texecom Premier LCD Keypad with Prox
£77.08 Ex VAT
Premier LCD keypad with Built in Proximity Tag [DBC-0001]  A range of high performance LCD and LED keypads featuring intuitive...
 More Info
Texecom PKK001 (pack of 5) Tags / Fobs
£27.57 Ex VAT
TEXECOM PKK001 PREMIER PROX KEYFOB Secware alternative click here
 More Info
Honeywell C020-01-KPROX G2-20 Keyprox Kit
£148.14 Ex VAT
Discontinued only available while stocks last Alternative ; [C005-E1-K22]   Description The G2-20 Keyprox Kit contains:   ...
 Sold Out
 More Info
Secware 6 core Intruder Alarm Cable
£11.00 Ex VAT
SecWare 100m 6 core intruder alarm cable is BS4737 compliant Very flexible cable, used for the cabling of intruder alarm and other low voltage...
 More Info
Enersys 12v 7.0 A/h Battery
£15.35 Ex VAT
 More Info
Accepted Cards
