CQR Aluminium Door Contact Grade 2
£9.12 Ex VAT
  • Model: GP001/G2
  • Shipping Weight: 0.5kgs
  • Manufactured by: CQR
  • In StoreOnline
Qty:
       Heavy Duty Contact
•      High Quality Alloy Finish
  • Double pole configuration
  • Pre-resistored (A,B)
  • Other resistor value available
  • 57cm Armoured cable lengths
  • EN50131-2-6 Grade 2
  • Environmental Class II
Unifix RG59 6mm FLAT White Clips
£2.24 Ex VAT
Flat Design Suits RG59 Type Cables White Finish Quality Build Flat white 6mm clips for our RG59 composite cable, with extra hard nails that resist...
 More Info
CQR 6 Core Screened Professional Intruder Alarm Cable
£38.31 Ex VAT
Screened security cable 100m 6 Core White Each core consists of 7 strands of 0.2mm annealed tinned copper wire and is sheathed in colour coded PVC....
 More Info
Yuasa NP7-12
£15.15 Ex VAT
 More Info
Knight Rubber Roller Shutter Spacer with YF10C Pk 5
£9.07 Ex VAT
150mm x 40mm x 10mm deep spacer for use with and Roller Shutter Contact. PARTICULARLY USEFUL IF YOU WANT TO FIT A G3 ROLLER SHUTTER -YF10C TO A METAL...
 More Info
CQR 6 Core Professional Intruder Alarm Cable
£33.59 Ex VAT
Standard security cable 100m 6 Core White Each core consists of 7 strands of 0.2mm annealed tinned copper wire and is sheathed in colour coded PVC....
 More Info
Knights YF10C2M 2M armoured cable Grade 3 roller shutter contact
£29.77 Ex VAT
  Knights YF10C2M 2 METRE armoured cable Grade 3 roller shutter contact Grade: 3       Grade 3 Universal Handed Roller...
 More Info
Accepted Cards
