Power over Ethernet or PoE describes systems which pass electrical power along with data on Ethernet cabling. This allows a single cable to provide both data connection and electrical power to devices such as wireless access points or IP cameras. Unlike standards such as Universal Serial Bus which also power devices over the data cables, PoE allows long cable lengths. Power may be carried on the same conductors as the data, or it may be carried on dedicated conductors in the same cable.
- 960H
- AHD/TVI
- Brackets
- Cameras
- CCTV Ancillaries
- CCTV Kits
- Consumables
- Detection
- Digital Recorders
- HD-SDI
- Housings
- Infra Red
- IP
- Lenses
- Monitors
- POE
- Switchers
- Telemetry
- Transmission
- VCR's
- Wireless CCTV
Specials
Dantech Quad Relay
£24.44
£19.55 Ex VAT
£19.55 Ex VAT
POE
£517.19 Ex VAT
Product Overview The Elmdene 4HR UPS™ Range has been designed as a cost effective solution for providing extended standby power to critical...
£620.61 Ex VAT
£339.70 Ex VAT
£75.72 Ex VAT
Product Overview When providing standby power for a PoE switch using a 240V ac UPS it is often difficult to achieve the required battery back...
£270.00 Ex VAT
Description H.265 Linux-based embedded standalone NVR. Equipped for up to 4-CH network cameras, the NVRs feature well-built ONVIF compliant and...
£638.00 Ex VAT
Description H.265 Linux-based embedded standalone NVR. Equipped for up to 16-CH network cameras, the NVRs feature well-built ONVIF compliant and...
£53.71 Ex VAT
For use with the AXIS 206, AXIS 206M, AXIS 207, AXIS 207W and AXIS 207 MW Network Cameras. Note: The AXIS PoE Active Splitter 5V AF is IEEE...
