Specials
Secware Enclosed Flood 400w Black
£6.87
£5.50 Ex VAT
£5.50 Ex VAT
Sorry, the product was not found.
Featured Products
£62.49
£49.99 Ex VAT
£49.99 Ex VAT
2 programmable zones Activate end of line monitoring 30 fire detectors per zone Unlimited number of call points per zone Integral manual...
£105.00 Ex VAT
Main Features • 1/2.8 "Panasonic COMS • Low power consumption, capture moving images without jagged edges and smear •...
£92.03
£73.62 Ex VAT
£73.62 Ex VAT
4 programmable zones Activate end of line monitoring 30 fire detectors per zone Unlimited number of call points per zone Integral manual...
£10.65 Ex VAT
Obsolete Memory control, remote led control, Signal count, led disable, low voltage alarm, S.P.S.T. (lb) alarm output TAKEX newly developed 4-bit...
£74.89
£73.13 Ex VAT
£73.13 Ex VAT
£78.39 Ex VAT
* 2 programmable zones * Activate end of line monitoring * 30 fire detectors per zone...
Monthly Specials For March
£26.23
£23.60 Ex VAT
£23.60 Ex VAT
Obsolete - only avaliable while stocks last Alternative click here Genie GTA001 Active Video Audio & Data Transmitter Product Overview Active...
£59.99
£53.99 Ex VAT
£53.99 Ex VAT
GVGA-CONV, High Resolution Video To VGA Converter High Resolution Video to VGA Converter with BNC Loop Out, Supports PAL or NTSC Video Systems,...
£286.00
£257.40 Ex VAT
£257.40 Ex VAT
Product Overview The ACTsmart2 PC Interface Controller is a stylish, robust and durable polycarbonate unit with LED indicators. It comes complete...
£200.00
£160.00 Ex VAT
£160.00 Ex VAT
Miniprox Proximity Reader, charcoal grey with terminal connections Accepts 5- to 16-volts, meeting most voltage requirements. Available with...
£16.50
£14.85 Ex VAT
£14.85 Ex VAT
Obsolete - Avaliable while stocks last Alternative Click Here Genie - 4-Channel Video Transceiver 4 x BNC to 1 x RJ45 and 1 x 8 Way Terminal Strip,...
£286.00
£257.40 Ex VAT
£257.40 Ex VAT
New Products For March
£88.60 Ex VAT
Green weatherproof double pole square break glass. Double pole weatherproof emergency door release. Ideal for outdoor installations or situations...
£4.51 Ex VAT
Manufactured from durable materials to endure varying weather conditions, this easy-to-install bracket adjusts the angle of the DoorbellCam by...
£38.61 Ex VAT
Videx 4872 2 Module Flush Rainshield for the 4000 Series The 4872 rain shield offers additional protection without detracting from the...
£131.22 Ex VAT
New-generation TAKEX twin beam redesigned for improved performance, easy alignment, and reduced energy consumption. PB-60TX features an...
£115.00 Ex VAT
Brand new but seal is broken on box. Box contents Fitting kit - Net2 plastic supports Fitting kit - RS485/232 or TCP/IP comms...
£107.69 Ex VAT
The Pyronix DOORBELL/KIT-SDC is a smart HD video doorbell and wireless chime kit that allows you to receive real-time alerts from the front door and...
£364.70 Ex VAT
KIT-1005 32 Zone Hybrid Wireless Kit Protecting your home or business is a top priority, and the KIT-1005 32 Zone Hybrid Wireless Kit from...
£1.68 Ex VAT
Proximity fobs for all Videx Vprox controller based and standalone systems. Proximity fobs are numbered to allow manual programming where its more...
