Shopping Cart Item(s) 0 | Total: £0.00
Security Warehouse
Silverline Security Light with built in CCTV camera and recorder
£77.61
Model: 901.271
Shipping Weight: 0.5kgs
0 Units in Stock
Manufactured by: Silverline
Sold Out
The new Silverline security light DVR is the definition of an all in 1 solution.
The IP rated external unit features a built in 500W halogen light, a passive infra-red motion sensor, a colour camera and a DVR that records onto a SD card.(not included)
Upon detection of movement, the PIR activates the camera and the record function. The halogen light is controlled by an adjustable lux level so can be set to come on all day or just at night.
The unit is around the same size and shape as standard PIR activated lights making it almost indistinguishable to tresspassers as a recording unit.
Recorded footage can be played back on any compatible media playing software simply take out the SD card and put it in the PC.
PIR Detection Angle of 52 degrees and detection range up to 9m
Colour CMOS Sensor up to 2.0 Megapixels
Max Resolution 1600x1200
Single Picture, Two Picture burst or 10 second video clip options
25fps @ 320x240 Video recording
LCD Display
IP44 Rated
Time & Date Stamping
500W Halogen R7S Floodlight Bulb
Up to 2Gb SD Card Accepted
Lux control to determine light level when unit is turned on
Alternative
Alert Cam £69.98
£7.44
  A sleek white low profile louvre-free housing containing either a 16 ohm or 8 ohm speaker, that will blend discreetly into any surrounding...
CQR SOINT1 NTERNAL TAMPERED EXTENSION SPEAKER 16 OHM WHITE G3
£6.31
XL Cover to suit Vertical Flashguard Backplates
Klaxon Flashguard Flashguard XL White/Blue Cover
£33.20
V-Series With Flashguard V-Series Security Sounders you can pick your lid from a choice of three sleek designs and choose your sounder unit from a...
Klaxon Flashguard Premier Vertical Backplate, req Cover
£76.01
AX-100PLUS & AX-200PLUS are the industry's most full-featured short range photobeams. 'Finger-Touch' alignment controls and precise beam...
Optex AX-100 PLUS Synchronised Twin Active Beam 30m NO/NC Relay
£34.23
8 Zones Each one is separately identified on the keypad and provides ample security detection for most domestic properties. 3 part set programs...
ADE Honeywell Accenta Mini Gen4 with LED Keypad
£8.27
Enersys 12v 2.3 A/h Battery
Copyright © 2014 SecurityWarehouse.
